eg opens with empty window
jojo
Post by jojo »
Last week I installed EG and succesfully setup for my x10 remote. Yesturday, when I wanted to modify the configuration it opens with an empty window, only showing menubar, toolbar and status bar. See
Screenshot showing empty window
After downloading and installing the new version 0.4.1.r1.5.40 the problem was solved and I began to forget this inexplicable happening. That was yesterday... Today, opening eg, again I have this empty window. Re-installing does not help. Now I am lost.
eg responds to events as configured, but see no eventlog and can't configure eg.
My system: xp pro SP3 32 bit, 319 MB RAM.
Please help
ijourneaux
Re: eg opens with empty window
Post by ijourneaux »
Sorry. Off hand I can't point you to the correct message but the solution is in the forum. I had the same problem and someone was able to point me to the answer.
Take Care
Try delete the "Config.py" file in EGs application data folder. Should be located in something like:
C:\Documents and Settings\[USERNAME]\Application Data\EventGhost\Config.py
jojo
Post by jojo »
Yes, thats it. After second attempt (had to close eg before removing config.py :P )
Thanks a lot :D
