How do I reload plugin
TheOgre
Post by TheOgre »
Hi Guys,
It's my first day trying to write a plugin, so go easy on me..
After I have made changes to the plugins .py file, what's the best way to get it to reload?
Looks like I either have to delete the plugin (along with any actions) from the tree. Or close EG and restart it.
Is there an easier way to just do a reload/refresh?
Re: How do I reload plugin
TheOgre wrote:Is there an easier way to just do a reload/refresh?
I do not know if it's the easiest way, but I use restart EventGhost from the menu.
It's simple. Just run the program with a command line argument -debug:
bruinlax
Post by bruinlax »
thanks. I was having the same problem.
cfull1
Post by cfull1 »
When I try to start it with -debug it just freezes.
Any ideas?
Also I noticed the restartprogram from the debug menu. Is there a way to call that from a python script?
For me as well, I thought I had a local problem
cfull1
Post by cfull1 »
Figured mine out.
I traced it back to a crappy plugin I threw together.
C:\Users\Carson\AppData\Roaming\EventGhost\Log.txt
Removed the plugin and it worked fine
Also Figured out how to do the restart:
eg.app.Restart()
