Been using directory watcher for years on some network folders and now after updating eventghost it does not work for the network paths. It works fine for a local folder just not a network path. Directory watcher says version 1.0. Is there a 2.0 and is so where can I find it? I've ran searches through the entire forums for it.
Example Path:\\HTPC\Torrent-Finished\TV
Has worked for years, now I get no events.
I also tried the path on a mapped network drive which I tried years ago and it never worked. Only the network path above ever worked but I thought I would give it a try.
Example Path:G:\Downloads\Torrent-Finished\TV (G: is a network drive)
This gives me no events as well.
Local C: drive path works just fine. Gets all the normal events.
C:\Test
Eventghost is running a a VM on Win7x86 and the path is to the host machine running Win7x64
Any help would be appreciated. Thanks.
Got it working again. No idea why but I had to redo the credentials to access the network path. Then, after restarting eventghost, it worked again. All is well.
