I've never been able to create a new profile. Just tweak existing. Here are my steps. Please tell me what is up.
(If I could attach a picture, it would save a thousand words)
Start EventGhost, create New, add MCE Remote Plugin
On the left side I see the reception of remote button presses, (and mouse clicks, and system events - sure would be nice to turn that noise off)
I add a macro on the right side, cancel the wizard, rename it to what I want (this case 0)
I add an Event. When I click the 0 on the remote I get MceRemote.3780 on the left, so I rename the Event to the same...
I do the same for a few more buttons...
Now, whether I add an action or not, when I press any of the programmed buttons, and EventGhost definitely sees the codes, it won't pop to the desired macro.
(I have "Autom Highlight on Event" Checked)
And something else I discovered a while ago, is when I make change, I have to save, close EventGhost and open again to see my change. This doesn't seem right...
Thanks in Advance..
Frank
Can't create new xml
- Bitmonster
Re: Can't create new xml
Thats what the "log only assigned and activated events" check box is for.zehd wrote:On the left side I see the reception of remote button presses, (and mouse clicks, and system events - sure would be nice to turn that noise off)
Your remote doesn't seem to be a original MCE remote (as they deliver named events and no hex codes). What kind is it?zehd wrote:I add an Event. When I click the 0 on the remote I get MceRemote.3780 on the left, so I rename the Event to the same...
You must have a typo in the event name. EG is case sensitive. Better drag and drop the event from the logger.zehd wrote:Now, whether I add an action or not, when I press any of the programmed buttons, and EventGhost definitely sees the codes, it won't pop to the desired macro.
Yes, there was a bug in the MCE plugin that prevented proper initialization after a fresh add to the configuration. Get the latest beta.zehd wrote:And something else I discovered a while ago, is when I make change, I have to save, close EventGhost and open again to see my change. This doesn't seem right...
Sorry I wasn't clear. I know what that check is for. It's so you don't see the noise AFTER you have a remote programmed. I would wish to see less niose in the log window especially when I'm programming a remote, and copying the text, the mouse clicks get in the way.Bitmonster wrote:Thats what the "log only assigned and activated events" check box is for.zehd wrote: (and mouse clicks, and system events - sure would be nice to turn that noise off)
I should have said that the very same thing happens when I use the MCE Remote. I'm trying it with a Hauppauge remote. But if you want we can just say that I'm using the MCE remote from this point forward.Your remote doesn't seem to be a original MCE remote (as they deliver named events and no hex codes). What kind is it?zehd wrote:I add an Event. When I click the 0 on the remote I get MceRemote.3780 on the left, so I rename the Event to the same...
I recognize that it is case sensitive. That's why I do not type in the text myself. I copy the text from the log and paste it into the event...You must have a typo in the event name. EG is case sensitive. Better drag and drop the event from the logger.zehd wrote:Now, whether I add an action or not, when I press any of the programmed buttons, and EventGhost definitely sees the codes, it won't pop to the desired macro.
I will try by dragging and dropping
Yes, there was a bug in the MCE plugin that prevented proper initialization after a fresh add to the configuration. Get the latest beta.[/quote]zehd wrote:And something else I discovered a while ago, is when I make change, I have to save, close EventGhost and open again to see my change. This doesn't seem right...
I have tried the beta, and that's where I saw too much system idle and mouse left click stuff whenever I try to programme
- Bitmonster
1. Ok, the left/right mouse events are an overkill. I had added them recently on a request, but I find them superfluous and bothering too. Removed from the latest beta...
2. Are all buttons hex codes on the hauppauge?
3. Oh, that was the missing link. I have never tried to paste them "as text" to rename them. There was a bug, as the text had a leading space in the copied text. Copy and paste of a whole event from the logger worked. Fixed in the latest beta.
The newest beta works well. Thank youBitmonster wrote:1. Ok, the left/right mouse events are an overkill. I had added them recently on a request, but I find them superfluous and bothering too. Removed from the latest beta...
