Asterisk AMI Plugin
TheOgre
Asterisk AMI Plugin
Post by TheOgre »
Hi All,
Here is my first plugin, I'm new to Eventghost and Python so please be nice. It's quick and dirty, and I'm sure there are better ways to do what I am doing - but it seems to work for the intended purpose.
This plugin connects to an asterisk box via the AMI interface. It generates an eventghost event each time it receives an event from the AMI.
Just as an example, this could be used to perform an action on an incoming call - Like a popup message with the callerid within xbmc.
To enable the AMI interface on your asterisk box, you will need to modify /etc/asterick/manager.conf
[general]
enabled = yes
port = 5038
bindaddr = 0.0.0.0
[eg]
secret = eg
permit=0.0.0.0/0.0.0.0
read = system,call,log,verbose,command,agent,user,originate
v0.1.0 - 2011-10-12 - Initial release
v0.2.0 - 2011-10-12 - Added filtering
(6.95 KiB) Downloaded 204 times
TheOgre
Re: Asterisk AMI Plugin
Post by TheOgre »
Ok, so I thought I'd add an example.
This is how you can send the CallerID of an incoming call to XBMC.
I've added 2 plugins to the Configuration tree - Asterisk AMI and XBMC2
I've created a macro with a Python Script, and used the AsteriskAMI.Newstate event to trigger it
The Python script is as follows:
if type(eg.event.payload) is dict \
    and 'ChannelStateDesc' in eg.event.payload \
    and 'CallerIDNum' in eg.event.payload \
    and eg.event.payload['ChannelStateDesc'] == 'Ring':
        eg.plugins.XBMC2.SendNotification(u'Incoming Call', eg.event.payload['CallerIDNum'])
This looks very nice!
What download sw package do you recommend for asterisk? For Windows or Ubuntu...
I see a great value for this using asterisk and connect to Skype. I found Skype2SIP but your inputs and experience/recommendation would be very much appreciated.
TheOgre
Post by TheOgre »
your best bet for asterisk is to use one of the pre-built distros. As long as you have a fairly recent pc, you should have no problem running it inside a virtual machine.
In the past I would always use trixbox for any asterisk install, but recently i've been using the freepbx distro with good results.
I haven't used the skype2sip plugin you mentioned, so I can't be much help there..
