Have a problem whit Switch King 2.0 and eventghost Tellstick Duo. In the new Switch King if you trigger the off setting then in Switch King menu changes to off. The scheduel is turned off. So my qestion is if its possible to add On - Off - Dim - Bell - Shed. The last would be very imortant for me.
Got a responce from Switch King. It resets itself to scheduel event on next triggert event so it seams that I dont need the Shed. Thanks Martin from Switch King (it rocks!).
