Using Same Key to Start & Exit An Application
mjw1024
Post by mjw1024 »
How do I setup a key that will launch an application and exit it as well? Example: I press the "DVD" key to start Zoom Player. If I press the same key while in Zoom Player, it will exit the application.
Bartman
Post by Bartman »
If pressing the DVD key is the only way you start ZP you can enable a close macro in the start macro and disable the start action. You have to use the "Stop processing this event" action in each of the macros. Otherwise both will run in circle.
The other way is to switch between the two macros with the task plugin, as it will give you events when an application is started or closed.
Post by Bitmonster »
And the third way is to use the FindWindow action. A layout like this:
Macro: Launch/Exit Zoom Player
Event: DVD
- Find Window: some window from ZP
- Jump: If successful to "Exit Zoom Player" and don't return
- Start Application: Zoom Player
Macro: Exit Zoom Player
- Zoom Player: Exit
This will even do the right thing if ZP was not started by EG.
