Webserver: More than one web page
EventGhost4ever
Post by EventGhost4ever »
Good evening,
I can't link my webserverplugin-page with a second webpage. If I do this and open the second webpage I get only the error code 404 (nothing matches the given URI).
HTML-code: <a href="2webpage.htm"> Second Webpage </a>
The second webpage is in the same folder as the first page.
But there is a problem. I have to take the html-file (C:\Program Files\...\www\Webserver.htm) instead of my folder (C:\Program Files\...\www\) as my data directory in the plugin adjustments. Otherwise I can't open the first webpage.
I were happy, if anybody knows a solution?
Re: Webserver: More than one web page
Perhaps you need to add more information or attach your files and screenshots.
I tried to simulate your situation, but I have come across no problem.
EventGhost4ever
Webser-Plugin adjustments:
I have to take the html-file (C:\Program Files\...\www\Webserver.htm) instead of my folder (C:\Program Files\...\www\) as my data directory in the plugin adjustments. Otherwise I can't open the first webpage (Webserver.htm).
Webserver.htm:
<html>
<head> <title>EventGhost</title></head>
<body>
<a href="?Flurlicht_an"> Flurlicht an </a><br>
<a href="?Flurlicht_aus"> Flurlicht aus </a><br>
</body>
</html>
2webpage.htm (same folder as Webserver.htm)
<html>
<body>
Hello world!
</body>
</html>
<html>
<body>
<a href="Webserver.htm?Flurlicht_an"> Flurlicht an </a><br>
<a href="Webserver.htm?Flurlicht_aus"> Flurlicht aus </a><br>
</body>
</html>
Only directory!
EventGhost4ever
Thanks Pako.
My problem was, that I used the URI without path (address.org/ instead of address.org/EventGhost.html).
