Action at the end of enduring event
maphix
Post by maphix »
I'd like to trigger an action at the end of enduring event. Is that possible somehow?
I'd like to to following:
When volume up key is pressed on remote I want to start action "button volume up pressed" and when the key is released I want to start action "button volume up released".
I use X10 plugin which creates enduring events correctly. I just didn't found anything in EventGhost which would allow me to trigger another action when enduring event ends.
Thanks in advance for help.
maphix
Re: Action at the end of enduring event
Post by maphix »
Anyone?
Suppose Test.Test is an enduring event.
Then the following script does what you need:
evt = eg.event
def TestEnd():
    if not evt.isEnded:
        eg.scheduler.AddTask(0.01, TestEnd)
        eg.TriggerEvent("Stop", prefix = "EnduringEvent")
eg.TriggerEvent("Start", prefix = "EnduringEvent")
TestEnd()
At the beginning is triggered event EnduringEvent.Start and at the end is triggered event EnduringEvent.Stop.
However, I do not know if it will have practical use.
I do not have the opportunity to try it.
