Terratec USB Reciever
chosl
Post by chosl »
Hi all!
I've had a EG running flawless for 6 months but for some strange reason my reciever just hung and I decided to upgrade my EG. Now I can't get it to work again :cry:
I'm running on Win7 x64 (tried on two systems). I've tried unstall and manually delete under c:\programdata too.
When I start EG it tells me it has found Terratec USB Reciever and when I add the plugin it installs it successfully but when it gets back to EG it says it cannot find it and tries to install it again?
I get an system event log error from DriverFrameworks-UserMode, event id 10101. "The driver package installation has failed. The final status was 0xE0000102."
The setupapi.dev in \windows\inf is huge but found this:
ndv: Installing device...
dvi: {DIF_INSTALLDEVICE} 22:15:58.955
dvi: No class installer for 'Terratec USB Receiver'
dvi: CoInstaller 1: Enter 22:15:58.955
inf: Opened PNF: 'C:\Windows\INF\oem84.inf' ([strings])
dvi: CoInstaller 1: Exit
dvi: CoInstaller 2: Enter 22:15:59.002
dvi: CoInstaller 2: Exit
dvi: CoInstaller 3: Enter 22:15:59.064
!!! dvi: CoInstaller 3: failed(0xe0000102)!
!!! dvi: Error 0xe0000102: The required line was not found in the INF.
After the driver installation it still says USB Input Device in the device manager, I tried a manual installation but still the same result. Did a Windows patch mess this up?
I also tried updating the hardwareID and guid in the __init__.py file for terratec to match mine but no luck.
Very grateful for any pointers or tips.
Thanks all!
