I have an application called Centrafuse 4.0, and I'm trying to use EG to send keystrokes to it in order to activate voice control. I've discovered that when the Centrafuse window does not have the focus, it accepts the keystrokes (ctrl+alt+v) sent by EG. However, when Centrafuse has the focus, it will ignore those keystrokes from EG. If I actually press ctrl+alt+v on the keyboard, Centrafuse accepts them, regardless if that window has the focus or not. This is the macro I'm using:
<Macro Name="Emulate Keystrokes: {Ctrl+Alt+v}" Expanded="True">
<Event Name="HID.Button.0" />
Window.SendKeys(u'{Ctrl+Alt+v}', False)
</Macro>Does anyone have any ideas on things I can try in order to get this working?
Thanks in advance.
keg
