Re-enable monitor not working.
shinyghost
Post by shinyghost »
I am using windows vista.
GTS450 latest drivers as of december 21st
two monitors hooked up one via dvi and the other hdmi.
My problem is the Re-enable monitor action does not do anything after I use the set monitor into power-off mode.
Any thoughts on solving this?
I did make sure that the action is properly triggering.
hotbuddha
Re: Re-enable monitor not working.
Post by hotbuddha »
Have you tried the HdmiOn program? Just google it, maybe it will help.
