I'd like to set my media center's volume level to a value which is stored in a variable.
Unfortunately, the python command eg.WinApi.SoundMixer.SetMasterVolume(77%, 0) produces the following error:
Error in Action: "eg.WinApi.SoundMixer.SetMasterVolume(77%, 0)"
Traceback (most recent call last) (1534):
File "<string>", line 1
SyntaxError: invalid syntax
Do you know the correct syntax?
Thx, G.
SetMasterVolume in Windows 7
Re: SetMasterVolume in Windows 7
eg.WinApi.SoundMixer.SetMasterVolume(77,0)Re: SetMasterVolume in Windows 7
Thanks a lot, Pako.
Calliope99
I installed the latest Creative sound drivers for my XFi, but i cant find the master volume control. All i find is a volume mixer. I usually would not care about this, but the sound is lower now than it used to be in win XP. So that probably means that the Wave volume control at the master volume control is at like 75%, but since i for some reason dont have master volume control i dunno how to increase the wave sound to 100%.
Does any1 have any idea? I heard that if u set winamp to 100% that it will increase the wave volume as well. Could any1 with win7 test that or help me increase my wave volume?
I tried to download an alternative maser volume control but that didnt work.
