I'm using the Conceptronics remote control and EventGhost to power on and off my Media PC and TV.
When I press the power button shortly the TV switches on or off. If I press it longer than one second the PC goes to standby mode. If I press it again shortly the PC wakes up from standby mode.
The problem is that on resuming from standby mode EventGhost often sends the power command to the TV. Allthough I put the "Clear pending events" function on the "System.Resume" event the "Conceptronic.Power" event is raised and handled.
I already put and "Wait: 5.0 sec" function before the "Clear pending events" function but this does not work reliably.
Any help is appreciated!
Best regards
Reaper
Log entries:
13:41:13 Conceptronic.Power
13:41:13 Power-Taste
13:41:13 If button is held down 1.0 sec, go to: Standby-Modus aktivieren
13:41:14 Standby-Modus aktivieren
13:41:14 Stand By
13:41:15 System.Suspend
13:41:32 System.ResumeAutomatic
13:41:32 Beim Reaktivieren aus Standby...
13:41:32 Clear Pending Events
13:41:32 Workaround f├╝r "iMON Manager"-Bug (WMI-Prozessauslastung durch Hardware-Scan beim Reaktivieren aus Hibernate)
13:41:32 Start Program: iMON Manager neu starten.bat
13:41:32 Workaround für EventGhost seit Build 4.1.r1509 (beim Reaktivieren aus Hibernate/Standby hängt es sich oft auf)
13:41:32 Conceptronic.Power
13:41:32 Power-Taste
13:41:32 If button is held down 1.0 sec, go to: Standby-Modus aktivieren
13:41:32 Jump to "Power"
13:41:32 Power
13:41:32 USB-UIRT: Transmit IR
"Clear pending events" function is not working
Re: "Clear pending events" function is not working
my solution:
where "Standby" is macro which is activated by "Power" button of my remote (X10).0:58:37 System resume
0:58:37 Clear Pending Events
0:58:37 Disable: Standby
0:58:37 Wait: 1.0 sec
0:58:38 Clear Pending Events
0:58:38 Enable: Standby
@ Vasilich:
Nice to see you here, too (beside MediaPortal forum)!
Thank you for your reply.
@ all:
I tried your solution but the problem still persists:
20:28:45 Conceptronic.Power
20:28:46 Stand By
20:28:47 System.Suspend
20:29:12 System.ResumeAutomatic
20:29:12 Clear Pending Events
20:29:12 Disable: Power
20:29:12 Wait: 1.0 sec
20:29:13 Clear Pending Events
20:29:13 Enable: Power
20:29:13 Conceptronic.Power
20:29:13 Power
20:29:13 USB-UIRT: Transmit IR
I think the problem is that the power key of the remote control pressed to resume the PC from Standby is remembered and executed regardless of the "Clear Pending Events" command.
Does anyone know how to solve that problem?
@ all:
20:28:46 Stand By
20:29:13 Power
