Find window & move window
malinduta
Post by malinduta »
Hello!
I`m trying to pause a macro until a window appears and then move it.
Finding the window work as expected if used separatly.
Moving the window work as expected if used separatly.
If both commands are in the same macro, it finds the window, but it DOES NOT move it.
Any ideas?
zian
Re: Find window & move window
Post by zian »
malinduta wrote: Finding the window work as expected if used separatly.
Any ideas?
Keep them separate (Jump To)?
eventghost.net
Be there or be square.
I tried it following way:
and it works well.
malinduta
Post by malinduta »
Pako wrote:I tried it following way:
The attachment PotPlayer_1.png is no longer available
The attachment PotPlayer_2.png is no longer available
and it works well.
I tried like you, Pako, and it`s working well.
After many hours of testing I realised it has nothing to do with finding window and moving it.
It has to do with On Screen Explorer.
If I put "Wait" for 5-10 sec after OSE, it`s working, but not always.
I guess OSE is somehow "locking" the window. Not very sure.
I'm trying it this way:
And it works very smoothly, always.
malinduta
Post by malinduta »
Pako, "Search invisible items also" was the trick. Now it works.
But not as expected.
If I move window to Monitor 1, everithing is ok.
If I move window to Monitor 2, the window dissapear (sometimes). It`s somewhere on Monitor 2, but it can`t be seen. The coordinates are X=0, Y=0. Also tried different coordinates on Monitor 2, same results.
I tried to right click on taskbar and select "move". Sometimes the window comes from outside the monitor (right side), sometimes it never shows.
Any thoughts?
I have not got the opportunity to test this behavior.
So I can not help.
Did you try to use the action Bring to front after action Move Absolute ?
malinduta
Post by malinduta »
I managed to "trick" it :)
My 1st monitor resolution is set to 1280x1024.
The command is to move window to Monitor 1 at 1900x300. It`s working!
