OSD as a TopMost Window?
dopdahl
Post by dopdahl »
Searched and couldn't find a reference to this issue.
I'm using the OSD action to display a small text window when I toggle some modes.
Problem is, the OSD window doesn't display topmost so when I'm running MediaCenter full screen, I never see the popup.
Anyone have an easy way to do this?
Dave
dopdahl
Re: OSD as a TopMost Window?
Post by dopdahl »
Found an MCE plugin that will do the trick from the command line...
http://www.pcmediacenter.com.au/forum/t ... ge-pop-up/
Cheers.
EDIT: Better yet, used a python script to poke the plugin directly... it's faster than using the execute program action with command lines... see the thread link above...
