access procedures / variables of loaded plugin
bruinlax
Post by bruinlax »
what's the syntax to have a python script access a variable / procedure of a loaded plugin base?
for instance to run from a script something like:
print eg.plugins("MyPlugin").strVariable or
eg.plugins("MyPlugin").myProcedure()
where sample plugin base is:
class MyPlugin(eg.PluginBase):
    strVariable
    def myProcedure(self):
        print "hello world -2"
    def __init__(self):
        pass
    def __start__(. . .
        strVariable = "Hello World"
    def __stop__(self):
        pass
    def __close__(self):
Thanks. . .
Re: access procedures / variables of loaded plugin
The way I learned is to use a getter action like the following:
Here is you plugin slightly modified where I have added an action that will return you the content of "strVariable".
import eg
eg.RegisterPlugin()
    def __init__(self):
        self.strVariable = ''
        self.AddAction(HelloWorld)
    def __start__(self):
        self.strVariable = "Hello World"
        print "Started"
    def __stop__(self):
        print "Stopped"
        pass
        print "Closed"
        pass
class HelloWorld(eg.ActionBase):
    def __call__(self):
        return self.plugin.strVariable
To use this from a python script, you could typically do like this:
myMessage = eg.plugins.MyPlugin.HelloWorld()
print myMessage
So in summary, use an action to access a variable in the plugin.
bruinlax
Post by bruinlax »
cool. i can make that work. thanks.
The way that Krambriw said, is not the only one.
There is also another way to get or set the plugin variables.
You can see it in the following example:
<EventGhost Version="1544">
    <Folder Name="Test Variable" Expanded="True">
        <Macro Name="GetHelloWorld" Expanded="True">
                TestVariable.GetHelloWorld()
                EventGhost.PythonCommand(u'print eg.result')
        <Macro Name="SetHelloWorld" Expanded="True">
                TestVariable.SetHelloWorld(u'Test value')
        <Folder Name="Python scripts for access a variable / procedure" Expanded="True">
            <Macro Name="Set variable" Expanded="True">
                    EventGhost.PythonCommand(u'eg.plugins.TestVariable.plugin.strVariable = "New value"')
            <Macro Name="Get variable" Expanded="True">
                    EventGhost.PythonCommand(u'eg.result = eg.plugins.TestVariable.plugin.strVariable')
            <Macro Name="Execute procedure" Expanded="True">
                    EventGhost.PythonCommand(u'eg.plugins.TestVariable.plugin.myProcedure()')
Excellent toy for similar testing is the Python Shell (Help menu in EventGhost).
Attached is a modified testing plugin:
"TestVariable" plugin
(1.2 KiB) Downloaded 262 times
Dear Pako,
This is of course a nicer and very visible way since it is shown in the tree structure. If you prefer to have it more "hidden", and using a more advanced script with additional logic inside, built in calls to actions the way I showed could be the choice. Both ways will of course work.
krambriw wrote:If you prefer to have it more "hidden", and using a more advanced script with additional logic inside, built in calls to actions the way I showed could be the choice.
Dear Walter !
I do not understand your post. Or you misunderstood my post.
I mainly wanted to point out that access to plugin variables is possible even without getter action.
This can be useful especially in case of an existing plugin, which is inappropriate to intervene.
Best regards, Pako
Dear Pako,
You are absolutely correct, no misunderstanding, your way is the best.
krambriw wrote:You are absolutely correct, ..., your way is the best.
Dear Walter,
no, I do not think it. We can not say that variant using the eg.plugins.<PluginClassName>.plugin.<PluginVariable> is the best.
It is only one variant, suitable in certain cases. Likewise, a variant with a getter action is again most appropriate in other cases.
I'm thinking in particular cases when you can expect frequent use for less experienced users.
Best regards, Pako
