Stop chosen apps with System.Suspend
GBWebmaster
Post by GBWebmaster »
I have the following problem. I want to stop XBMC and MediaMonkey, when I suspend my system.
In other words: EG should check, if XBMC runs. And, if so, close XBMC, if not, do nothing. Then check, if MediaMonkey runs. And, if so, close MediaMonkey, if not, do nothing.
How can I realize this?
GBWebmaster
F├╝r den, der nie das Rudel anf├╝hrt,
Re: Stop chosen apps with System.Suspend
I can not say anything about XBMC, because I do not know anything about it.
But MediaMonkey I know.
You can try it this way:
Python Script:
if not eg.plugins.MediaMonkey.plugin.isRunning():
    eg.StopMacro()
GBWebmaster
Thank you Pako, now it works fine.
GBWebmaster
