Avoid repeating
Esperado
Avoid repeating
Post by Esperado »
I vant to use my Avermedia remote with 4 instances of DVBViewer: 3DVBpro and one DVBge ( 3 tuners ).
- When i use the plugin, it load the first instance of the program, even if an other one is selected and focused.
- Is there any way to avoid to swap between 1 and 11 when i want to change channels. I would like EventGhost to recognize the difference between one key pressed long (the time the channel appears to the program screen) and two different actions on the button '1' on the remote.
- The remote send keys via HID. When i use Event ghost, is any solution to intercept the remote and avoid the original keys to be send to the windows ?
Tried a lot of thinks (not really understandable or accurate) and nothing is satisfactory.
Thank in advance..
