just trying to figure out how to do this (guess it's in and I just can't find it):
If test.exe is running it should be closed, if it isn't it should be started.
I can make the "if" check work, but can't figure out how to do the "else" part.
Thanks in advance,
Lars
EDIT: just figured it out: create 2 macros (1+2) with the same event, and one without (3) an event. set (1) to find window and make it jump to (3). if the window isn't found (2) is run. don't forget to enable (1) and (2) in (3).
[solved] if window exists do A else B
please post example
could someone please post a example of your usage of this.
Scat
Scat
XkFnHLgSVDl7
Re: [solved] if window exists do A else B
this detects whether DScaler.exe is running, if yes it closes it, if not it starts D:\Media\DScaler\DScaler.bat
edit: oops, had a small bug in there, fixed now
<Macro Name="Close DScaler" id="88">
<Action>Window.Close()</Action>
<Macro Name="DScaler running?" id="92">
<Event Name="Keyboard.LShift+LCtrl+LAlt+M"></Event>
<Action>Window.FindWindow(u'DScaler.exe', None, None, None, None, None, False, 0.0, 2)</Action>
<Action>EventGhost.NewJumpIf(XmlIdLink(88), 0, False)</Action>
<Action>System.Execute(u'D:\\\\Media\\DScaler\\DScaler.bat', u'', 3, False, 2, u'')</Action>
<Action>EventGhost.AutoRepeat(1.0, 1.0, 0.01, 3.0)</Action>
</Macro>- Bitmonster
The code above is not suitable for pasting. You need to stuff the macros into a folder, then copy this folder and paste it here unmodified.
