Hi guys,
I'd like to do something which shouldn't be a problem for the experts here.
As I'm not, I'm just gonna ask:
I want to execute some macros just in case a special process is running.
If it's not the macro should stop.
I have several use cases for this. E.g. sometimes mediaportal won't close on close command so I want to check the macro a few seconds later if it is still running. If so I would run a kill.bat
Could you please help me out?
Luca
How to check status of process
- Luca Brasi
- Luca Brasi
Re: How to check status of process
Hey guys,
come on, this should be a no-brainer for you! Would be very grateful for some help!
Luca
Luca
- Luca Brasi
Sorted it out:
from win32com.client import GetObject
WMI = GetObject('winmgmts:')
eg.result = len( WMI.ExecQuery('select * from Win32_Process where Name="mediaportal.exe"') ) > 0Win10 x64 Prof. / Eventghost latest / MCE Plugin / MCE RC6 Receiver / Logitech Harmony Hub / MediaPortal / kodi
Thanks Luca for posting the solution. I didn't realize that I needed something like this until you posted the code.
- Luca Brasi
Thanks for your reply kalia.
Just want to mention that I took it from this german post
