New to EventGhost...need help with forwarding keypresses
chris00780
Basically I want to know if EventGhost can even do what I need it for. I have my Logitech Harmony working perfectly with XBMC WITHOUT using EventGhost. I just added a launcher that goes to SlingPlayer using XBMC. Right now when XBMC is active, when I press Stop on the remote, it sends an X keyboard press. Is there a way to have the Stop button (which is an X key) be interpreted as an S key only when SlingPlayer is active?...and a quick how to if this is possible? I did try searching, I'm just not sure if I searched the right words. Thanks in advance!
