Need a little help for X10 based remote
leaveme
Post by leaveme »
Hi:
I'm very new to EV and trying to learn. I recently bought a X10 based Mouse remote - UR86A with CM19A transceiver, which I'll be using with EV.
The remote works with the X10 remote plugin. However the volume action is reversed, "Vol+" decreases and "Vol-" increases the system volume. I thought, label on the remote might be wrong but then I found that "Vol+" generates the event "X10.VolumeUp" and "Vol-" generates "X10.VolumeDown".
Cursor also doesn't move by the mouse event. Any help will be appreciated.
Here is the list of the buttons and events:
            'One': 'Num1',
            'Two': 'Num2',
            'Three': 'Num3',
            'Four': 'Num4',
            'Five': 'Num5',
            'Six': 'Num6',
            'Seven': 'Num7',
            'Eight': 'Num8',
            'Nine': 'Num9',
            'Zero': 'Num0',
            'VolumeDown': 'VolumeDown',
            'VolumeUp': 'VolumeUp',
            'ChannelDown': 'ChannelDown',
            'ChannelUp': 'ChannelUp',
            'Mute': 'Mute',
            'A-B': 'ABSwitch',
            'A': 'Display',
            'B': 'Return',
            'C': 'Title',
            'D': 'PC',
            'Menu': 'Menu',
            'Exit': 'Exit',
            'OK': 'Enter',
            'Right': 'Right',
            'Left': 'Left',
            'Up': 'Up',
            'Down': 'Down',
            'Rew': 'Rewind',
            'FF': 'Forward',
            'Play': 'Play',
            'Stop': 'Stop',
            'Pause': 'Pause',
            'Record': 'Record',
            'MouseUp': 'MouseUp',
            'MouseRightUp': 'MouseRightUp',
            'MouseRight': 'MouseRight',
            'MouseRightDown': 'MouseRightDown',
            'MouseDown': 'MouseDown',
            'MouseLeftDown': 'MouseLeftDown',
            'MouseLeft': 'MouseLeft',
            'MouseLeftUp': 'MouseLeftUp',
            'Hand': 'FilledHand',
            'MouseLButtonDown': 'LButtonDown',
            'MouseLButtonUp': 'LButtonUp',
            'MouseRButtonDown': 'RButtonDown',
            'MouseRButtonUp': 'RButtonUp',
