Return DirectoryWatcher value within python.
_Certo_
Post by _Certo_ »
Hi All,
I've been trawling through the forums but haven't been able to find an answer to what im assuming is a pretty simple problem.
I'm just modifying a script, and i want to reference one of the directory watcher paths within a python script so as not to hard code the path.
Once i have that stored in a variable i only need to use it within that script so the rest should be pretty straightforward.
Thanks for any help, i love this program and i'm slowly moving all of my other automation tasks into it, the flexibility is astounding.
Cheers,
Adam
wakko
Re: Return DirectoryWatcher value within python.
Post by wakko »
eg.globals.<NameOfYourVariable> should help you out. If i understood your question right.
I.e., inside modified by you plugin:
eg.globals.MyVariableAccessibleFromOtherScripts = SomeVaiable
