Control VPN Connection
I've been searching around to no avail. Here is the situation. At specific times I want my computer to use a vpn connection and at certain times my normal connection. I would like to use eventghost to turn my vpn connection on and off at specific times.... Anyone?
Re: Control VPN Connection
What kind of VPN? If you are using OpenVPN you can use command line to start and stop the client.
I just tested the VPN connection/disconnection in Windows 7.
It works very reliably. I did it as follows:And here are the scripts:
Connection:Disconnection:Pako
Connection:
VPNname = "name of my VPN connection"
VPNusername = "my VPN username"
VPNpassword = "my VPN password"
from subprocess import Popen, SW_HIDE
args = ["rasdial"]
args.append('"%s"' % VPNname)
args.append(VPNusername)
args.append(VPNpassword)
Popen(args, creationflags=SW_HIDE, shell=True)Code: Select all
args = ["rasdial.exe"]
args.append("/disconnect")
