Help Plugin DenonSerial
gomestv
Post by gomestv »
resolved.
Hello, I needed some help in using EventGhost, but precisely in the use of DenonSerial Plugin, I have a Denon AVR-3311CI receiver that control through VoxCommando but the plugin does so above the control of phono inputs, TV, DVD and CD, the other I can not control, BD, SAT / CBL, DVR and GAME.
My question is how to edit the plugin so that it DenonSerial control these entries?
or some other way so that I can control?
thank
Jose Carlos
woggy
Re: Help Plugin DenonSerial
Post by woggy »
try to send a Denon RAW command, for GAME send:
SVGAME
If you send
SV?
it will output the name of your selected channel.
Here is the RS232 Manual
http://www.audioproducts.com.au/downloa ... V7.1.0.pdf
