COM ports won't stay the same
spyderespirt0
Everytime I open and close eventghost the ports are all at COM 3, and not to their respective COM ports. It's really getting to be annoying. Im using the serial plugin and CM11A plug in.
eatmeimadanish
Re: COM ports won't stay the same
You should really try using OpenSourceAutomation Engine instead of EG for this kind of stuff. http://www.opensourceautomation.com/
spyderespirt0
That didn't answer my question. And simply put im doing more than just using the x10 plugin I have alot of hardware interfaced with eventghost that tehe opensourceautomation cant do.
