Actionscript integration
Zazza
Post by Zazza »
Greetings,
can a EventGhost plugin communicate with Actionscript code? I'd like to use the dvbviewer plugin to work with a flash GUI.
Suppose you have a flash button that when clicked calls a function inside the dvbviewer plugin and returns a value (ie: channel number) or makes an action (ie: channel change).
Is it possible? Thanks...
