Smooth Auto Repeat
fivestar
Smooth Auto Repeat
Post by fivestar »
I'm using a Firefly Remote and the latest beta. I'm using the remote with a dj app that has a horizontal volume fader that "crossfades" between 2 sources. The keyboard map is set to use the keys G & J to fade left & right respectively.
I set up a macro that when a left arrow event comes in from the firefly to simulate a keypress of "G". I do the same for the right arrow and simulate a keypress of "J". I have set an auto repeat below both actions and have tried mutliple variations of time but can't seem to get a smooth transition like I can with the keyboard. Is there a workaround for this?
Greg Hodges
Re: Smooth Auto Repeat
Post by Bitmonster »
What are you exact settings?
Also keep EG minimized when doing time critical actions.
