alright i started using eventghost this morning and so far its pretty good.
I'm using the keyboard plugin but with a remote that came with my TV card to control mediaportal.
When i press a button on the remote, for example the power button, eventghost shows a series of key presses:
Keyboard.LCtrl
Keyboard.LCtrl+LAlt
Keyboard.LCtrl+LAlt+P
Keyboard.LAlt+P
Keyboard.P
now if any other button on the control uses one of those keys it will run the power action as well
so is there anyway to make an action only run if all of those keys are pressed?
Help with keyboard plugin
- Bitmonster
Re: Help with keyboard plugin
Does any other button on your remote generate a "Keyboard.LCtrl+LAlt+P" event? If not, you can simply use this one to identify the button, as it is the most specified sequence. Surely a "Keyboard.LCtrl" event assignment to a macro wouldn't make much sense, since every Ctrl key combination would trigger this.
