I have been having fun mapping my MVP Remote (same as 45 button Hauppage MCE Remote IIRC) with the USBUIRT using Eventghost (great program btw, IMO easier to learn than HIP).
I took the existing GB-PVR plugin and tried to modify it for PVRX2. It works OK for commands where I can activate the PVRX2 Window with the Macro commands OK, but any built in items like "GB-PVR: Down" gives me a "GB-PVR is not running" error?
I can't seem to (re)configure those commands.... is there any way to modify these? I tried changing GB-PVR: Down to PVRX2: Down, but nope..
Ta
k.
Is the Eventghost GB-PVR plugin compatible with GBPVR new PV
- Bitmonster
Re: Is the Eventghost GB-PVR plugin compatible with GBPVR new PV
The GBPVR plugin was only in the beta installer by accident. It is no longer supported. The next installer will not include it anymore.
Oh, that's a shame. Never mind, I'm sure I can do this using "send keystrokes.
Cheers
k.
Cheers
k.
