How make reinitialization of System Tray Menu ?
I seek solution of my Feature Request:
http://www.eventghost.org/forum/viewtopic.php?f=5&t=486 .
Seems, that everything work well.
Is here only one "small" problem. :cry:
I must open dialog System Tray Menu and push "OK".
I don't know make reinitialization like a Action.
It is at all possible ?
My editing.
(14.2 KiB) Downloaded 245 times
Re: How make reinitialization of System Tray Menu ?
Post by Bitmonster »
Rename __start__ to something else. Lets say CreateMenu. Then:
class SysTrayMenu(eg.PluginClass):
    def __start__(self, menuData=[]):
        self.menuData = menuData
        self.CreateMenu(menuData)
class ReinitMenu(eg.ActionClass):
    def __call__(self):
        self.plugin.__stop__()
        self.plugin.CreateMenu(self.plugin.menuData)
But I don't like the idea to create items on conditions very much. Menus shouldn't change the number of items if a condition changes. They should at best disable some of them.
Thanks !
Work it very well !
As it is simple, when it somebody be able to. :)
I have also preferably disable item, than hidden.
But I don't know how it make. :(
I don't know, where find needed information.
Therefore I am it made this way.
If would it that way work, may would it to be in distribution ?
I have new version of Sys Tray Menu - Dynamic Menu.
Now already work Enable/Disable Menu Items.
Modified Plugin.
(14.29 KiB) Downloaded 245 times
Dynamic menu DEMO.xml
Example using dynamic menu feature.
(1.59 KiB) Downloaded 146 times
I have uploaded a new version with "Enable" and "Disable" actions. They don't fit perfectly into the action design, because it is possible to delete menu items, while some Enable/Disable actions might refer to them, but it seems to work so far.
Hi !
Your solving is naturally better. A in addition (and it is essential), is a part of distributive version.
Thanks !
