How to use Event Payload as Action Parameter
SamWest
Post by SamWest »
I'm trying to write a plugin which will take my System.Volume's payload (ie the volume percentage) and pass it as a parameter to an Action in my plugin (so it will set my receiver's volume to the same level).
For example, I want to get the '28.00' bit from an event like:
System.Volume '28.00'
And call
MyPlugin.SetVolumeAbsolute(28)
I'm using the Python and XML code below, but getting this error.
TypeError: __call__() takes exactly 2 arguments (1 given)
Do I need to pass a reference to self into __call__(self, volume) or something? If so, how do I do that from the XML script?
My Action looks like this:
class SetVolumeAbsolute(eg.ActionBase):
    def __call__(self, volume):
        return self.plugin.setVolumeAbsolute(volume)
    def Configure(self, volume=25):
        panel = eg.ConfigPanel(self)
        valueCtrl = panel.SpinIntCtrl(volume, min=0, max=100)
        panel.AddLine("Set absolute volume to", valueCtrl)
        while panel.Affirmed():
            panel.SetResult(valueCtrl.GetValue())
And my XML like this:
<Macro Name="MyPlugin: Set Absolute Volume" Expanded="True">
        <Event Name="System.Volume" />
            MyPlugin.SetVolumeAbsolute(int(round(eg.event.payload)))
Sam.
Re: How to use Event Payload as Action Parameter
When you use panel.SpinIntCtrl, so you can not use the eg.event.payload
[only if you use eg.plugins.MyPlugin.SetVolumeAbsolute(...) in the Python Script action].
But I recently created a new control: eg.SmartSpinIntCtrl.
You can see how to use it for example in the AIMP plugin.
Look for the set_volume class (from line 496).
SamWest
Post by SamWest »
Sweet, thanks for that Pako, the SmartSpinIntCtrl got it working :)
I'll post the plugin in a new thread when I've tested/polished it a bit.
If anyone is interested in doing the same thing, here's my working plugin code:
        valueCtrl = eg.SmartSpinIntCtrl(panel, -1, 0, min=0)
And the Macro that passes the System.Volume payload to the Action:
<Macro Name="MyPlugin: Set Absolute Volume to 0" Expanded="True">
            EventGhost.PythonCommand(u'eg.plugins.MyPlugin.SetVolumeAbsolute(float(eg.event.payload))')
-Sam.
That is not correct.
When you're doing it in such a way, then you can use straight wx.TextCtrl instead of eg.SmartSpinIntCtrl and even then it would not be quite correct.
First of all, there are missing eg.ParseString() and curly braces.
If you want the user to remain possibility to enter a value using SpinInt, then it should look something like this:
    def __call__(self, volume=0):
        volume = str(volume) if isinstance(volume,int) else eg.ParseString(volume)
        return self.plugin.setVolumeAbsolute(float(volume))
            MyPlugin.SetVolumeAbsolute(u'{eg.event.payload}')
If you do not need to enter a value directly (but only as {eg.event.payload}), it is absolutely unnecessary to use eg.SmartSpinIntCtrl (as already mentioned). In that case, use wx.TextCtrl.
