It keeps asking me to install the CLLRCMCE driver but doing that doesn't help. Clicking Yes actually launches the driver installation wizard and it completes successfully. But right after the installation it will ask me to install the driver again and that goes on into infinity.
What I tried:
- I uninstalled the driver from Control Panel > Programs and Features.
- I deleted the driver installer and let EG download and install it.
- Ran the driver installer myself.
- I installed the "EventGhost WinUSB Add-on" and "USB-Remote-Driver" from http://www.eventghost.net/downloads/ to see if it had any effect.
- Clean EG install and clean xml.
Some more info:
- The driver is in the list of installed programs: "Windows Driver Package - EventGhost Conceptronic CLLRCMCE (01/25/2010 1.0.2.0)"
- I can confirm that the files are placed in C:\Windows\System32\DriverStore\FileRepository\driver.inf_amd64_neutral_8371a1a2f2e6896f\
WdfCoInstaller01009.dll
WinUSBCoInstaller2.dll
driver.PNF
driver.inf
- The remote does work, but on the default driver so EventGhost doesn't catch the events and default behavior is not good enough for MediaPortal!
- It's too late for restore point.
System:
EventGhost 0.4.1.r1600
Win7 Pro x64
Possibly some relevant logs:
EventGhost log:
15:56:50 Plugin: Conceptronic CLLRCMCE
15:56:50 Error starting plugin: Conceptronic CLLRCMCE
15:56:50 Driver not found!
15:56:55 GetUncPathOf Error: 1200 The specified device name is invalid.
15:57:11 Error starting plugin: Conceptronic CLLRCMCE
15:57:11 Driver not found!Code: Select all
TThe driver package installation has failed. The final status was 0xE0000102.Twice actually, 1 second apart.
C:\Windows\setupact.log (possibly relevant?):
[12/13/2012 15:57.08.779] WinUSBUpdate: installing version (6,1,7600,16385).
[12/13/2012 15:57.08.779] WinUSBUpdate: Checking for presence of previous WinUSB installation.
[12/13/2012 15:57.08.779] WinUSBUpdate: Found binary %WINDIR%\system32\drivers\winusb.sys version (6.1.7601.17514)
[12/13/2012 15:57.08.794] WinUSBUpdate: Found binary %WINDIR%\system32\winusb.dll version (6.1.7600.16385)
[12/13/2012 15:57.08.794] WinUSBUpdate: WinUSB installation is newer than update.
[12/13/2012 15:57.08.794] WudfUpdate: installing version (1,9,0,7600).
[12/13/2012 15:57.08.794] WudfUpdate: Checking for presence of previous UMDF installation.
[12/13/2012 15:57.08.794] WudfUpdate: Found binary %WINDIR%\system32\drivers\wudfrd.sys version (1.11.0.0)
[12/13/2012 15:57.08.810] WudfUpdate: Found binary %WINDIR%\system32\drivers\wudfpf.sys version (1.11.0.0)
[12/13/2012 15:57.08.810] WudfUpdate: Found binary %WINDIR%\system32\wudfhost.exe version (1.11.0.0)
[12/13/2012 15:57.08.810] WudfUpdate: Found binary %WINDIR%\system32\wudfsvc.dll version (1.11.0.0)
[12/13/2012 15:57.08.826] WudfUpdate: Found binary %WINDIR%\system32\wudfx.dll version (1.11.0.0)
[12/13/2012 15:57.08.826] WudfUpdate: Found binary %WINDIR%\system32\wudfplatform.dll version (1.11.0.0)
[12/13/2012 15:57.08.826] WudfUpdate: Found binary %WINDIR%\system32\wudfcoinstaller.dll version (1.11.0.0)
[12/13/2012 15:57.08.826] WudfUpdate: UMDF installation is newer than update.
[12/13/2012 15:57.08.826] WudfUpdate: Loading configuration coinstaller from C:\Windows\system32\wudfcoinstaller.dll.
[12/13/2012 15:57.08.841] WudfCoInstaller: ReadWdfSection: Checking WdfSection [Install.Wdf]
[12/13/2012 15:57.08.841] WudfCoInstaller: error finding key UmdfServiceOrder in section [Install.Wdf] in INF - C:\Windows\INF\oem36.inf.
[12/13/2012 15:57.08.841] WudfCoInstaller: Final status: status(E0000102) <no error text>
WdfCoInstaller: [12/13/2012 15:57.08.841] DIF_INSTALLDEVICE: Post-Processing
WdfCoInstaller: [12/13/2012 15:57.09.404] DIF_INSTALLDEVICE: Pre-Processing
WdfCoInstaller: [12/13/2012 15:57.09.529] ReadComponents: WdfSection for Driver Service WINUSB using KMDF lib version Major 0x1, minor 0x9
[12/13/2012 15:57.09.529] WinUSBUpdate: installing version (6,1,7600,16385).
[12/13/2012 15:57.09.529] WinUSBUpdate: Checking for presence of previous WinUSB installation.
[12/13/2012 15:57.09.529] WinUSBUpdate: Found binary %WINDIR%\system32\drivers\winusb.sys version (6.1.7601.17514)
[12/13/2012 15:57.09.529] WinUSBUpdate: Found binary %WINDIR%\system32\winusb.dll version (6.1.7600.16385)
[12/13/2012 15:57.09.529] WinUSBUpdate: WinUSB installation is newer than update.
[12/13/2012 15:57.09.529] WudfUpdate: installing version (1,9,0,7600).
[12/13/2012 15:57.09.529] WudfUpdate: Checking for presence of previous UMDF installation.
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\drivers\wudfrd.sys version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\drivers\wudfpf.sys version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\wudfhost.exe version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\wudfsvc.dll version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\wudfx.dll version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\wudfplatform.dll version (1.11.0.0)
[12/13/2012 15:57.09.529] WudfUpdate: Found binary %WINDIR%\system32\wudfcoinstaller.dll version (1.11.0.0)
[12/13/2012 15:57.09.544] WudfUpdate: UMDF installation is newer than update.
[12/13/2012 15:57.09.544] WudfUpdate: Loading configuration coinstaller from C:\Windows\system32\wudfcoinstaller.dll.
[12/13/2012 15:57.09.544] WudfCoInstaller: ReadWdfSection: Checking WdfSection [Install.Wdf]
[12/13/2012 15:57.09.544] WudfCoInstaller: error finding key UmdfServiceOrder in section [Install.Wdf] in INF - C:\Windows\INF\oem36.inf.
[12/13/2012 15:57.09.544] WudfCoInstaller: Final status: status(E0000102) <no error text>
WdfCoInstaller: [12/13/2012 15:57.09.544] DIF_INSTALLDEVICE: Post-Processing
