Error while saving file
Denniswenger
Post by Denniswenger »
Hello
Every time I try to save my trees I get the message "Error while saving file".
From the log
From the log
I don't understand why. Anyone got any ideas?
Clyde
Re: Error while saving file
Post by Clyde »
No idea, but same problem. After adding new plugin saving is impossible. :roll:
It is a problem specifically related to that plugin (AutoRemote). If you look around, you will find that the author is looking to find a solution to his problem.
