How can I make a macro that goes something like this:
When I press Windows MCE button it disables keyboard emulation (I did this with ease) BUT after the program wouldn't be in the memory anymore it would enable keyboard emulation again automatically. I can see that there is a "find a window" and such but I need just the opposite! "when program is not on anymore, enable keyboard emulation".
The recommended way is to use the "Task Create/Switch Events" plugin and wait for the destroy (or even the deactivated) event of the application. With this event you can switch back to your general keyboard emulation context.
No. It uses a hook Windows is specially supplying for such purposes.
Finding windows (or finding their non-existence) is much more computation intensive.
