Device Removed & Device Attached Issue
u0159419
Post by u0159419 »
hi,
I am using Evenghost and DVBViewer and nearly everything runs fine.
My Setup is a HTPC plugged into a Yamaha AVR, which is connected with my LG LCD-TV
Everytime when I shutdown my TV, Eventghost logs following:
Device Removed (LG124544..........)
Device Attached (NV5454545.........)
When I try to assign an event to "Device Removed (LG124544..........)" then Evenghost only takes the part "Device Removed"
Is this a bug?
How can I force EG to run the event only if a secific Device is removed? The ID of the Devices in bracket are always unique (in my case)
Re: Device Removed & Device Attached Issue
Search the forum for payload
