Hi there,
I downloaded yesterday EG and the Radio Sure plugin and founf two issues:
1) The scheduler does not work reliably and sometimes cannot be edited or the functions such as duplicate, delete do not work.
2) The scheduler window is incomplete at the bottom: the "destination file" menu cannot be accessed (s. attachement page 1)
3) When a new schedule is registered, there is an error message (s. attachement page 2)
I Iuse Windows 7 Home Premium and the latest version of R/S (2.2.1037), EG (0.4.1.r1600) and scheduler plugin (0.2.21).
Any ideas how to fix this? Help very much appreciated
Radio Sure plugin issues
Re: Radio Sure plugin issues
I'm still waiting until I can see the promised attachment.mesguerra wrote:2) The scheduler window is incomplete at the bottom: the "destination file" menu cannot be accessed (s. attachement page 1)
Hello Pako,
sorry, uploading of attachement did not work before.
Regards
ME
Regards
ME
- EG Radio Sure Scheduler.7z
- (121.95 KiB) Downloaded 126 times
Yes, it could happen.mesguerra wrote:2) The scheduler window is incomplete at the bottom: the "destination file" menu cannot be accessed (s. attachement page 1)
You have probably set the font size to a value greater than 100%.
Such a case I did not expect. However, I fixed it and you can download the new version here (right mouse button and Save target as ...).
So in this case I could not get the same behavior. For me everything was fine. If you continue to have this problem, you have to exactly describe all the steps that result to this behavior.mesguerra wrote:1) The scheduler does not work reliably and sometimes cannot be edited or the functions such as duplicate, delete do not work.
