Here is a new plugin Android Notifier.
This plugin receives notifications from the Remote Notifier for Android by Rodrigo Damazio.
If you are using Tasker (or Locale) also, you can also take advantage
of the Tasker/Locale plugin Locale Remote Notifier Plug-in.
This (EventGhost) plugin support only UDP broadcast.
Encryption of notifications is supported (optional).
You must also configure the Android application Remote Notifier for Android for this.
Android Notifier
Android Notifier
- AndroidNotifier.zip
- Plugin Android Notifier - version 0.0.1
- (4.14 KiB) Downloaded 184 times
