I previously set up EventGhost with Streamzap plug in to work with my Streamzap remote, which has worked flawlessly for several months. I had disconnected the Streamzap Receiver for about a month. When I plugged it back in to my computer, I received the Found New Hardward message from Windows XP. Whether or not I allow Windows to recognize hardware (ie., install Streamzap driver), the Streamzap remote signals are no longer recognized by EventGhost. In running the EventGhost xml file, I receive the following error description. Please help...
Plugin: Streamzap PC Remote
Unhandled exception in thread started by
File "C:\Program Files\EventGhost\eg\MainLogger.py", line 107, in write
wx.CallAfter(self._LoggerCtrl__OnWrite, data, 1)
File "wx\_core.pyc", line 13824, in CallAfter
File "wx\_core.pyc", line 7554, in GetApp
File "C:\Program Files\EventGhost\plugins\Streamzap\__init__.py", line 147, in ReceiveThread
"the driver."
PluginTools._Exception: 'Cannot open Streamzap driver!\nPlease check that the receiver is connected properly and no other application is accessing the driver.'
Main.OnInit
Main.OnInitAfterBoot
System.Idle
System.UnIdle
System.Idle
System.UnIdle
Assistance with Using Streamzap
- Bitmonster
Re: Assistance with Using Streamzap
Try to install the complete driver from here:
http://www.streamzap.com/downloads/
After that disable the tray application.
