"Disable HID device" - Wake pc from sleep still possible?
Bad_Karma
Post by Bad_Karma »
I'm using a RC6 MCE remote to control my HTPC.
I just read I need to select option "Disable HID device" to avoid double key presses.
Will I still be able to wake my pc from sleep with the IR remote if I enable this option?
gaddster
Re: "Disable HID device" - Wake pc from sleep still possible
Post by gaddster »
you've probably already found out the answer but yes it will work.
