Ok, so I have a Directv RC65 Remote, which is capable of RF, and a USB PC Adapter for the Xbox 360 controller on my PC. So is it possible to program a directv remote to use RF with the USB adapter to control XBMC?
If so or, if you think its possible, where do i begin? I have eventghost, but i have no idea how to use it, would love to get this to work if it is in anyway possible so i dont add another remote.
IR is not an option, if im going to use the Directv remote is has to be able to respond to the USB adapter.
in case you dont know what adapter i mean, it is....
http://www.amazon.com/Xbox-360-Wireless-...B000HZFCT2
is there an eventghost plugin that will recognize the Directv remote, if so which?
DirecTv In RF mode for XBMC
Re: DirecTv In RF mode for XBMC
Not in RF mode.is there an eventghost plugin that will recognize the Directv remote, if so which?
