SessionLock/Unlock triggers multiple times
eventspook
Post by eventspook »
I'm trying to create an event which triggers when I lock or unlock my screen. This works great, however, locking/unlocking the screen seems to trigger the SessionLock/SessionUnlock event multiple times (4 times in a row most of the times).
When I start a new/blank configuration file (with only the 'AutoStart' item in the config tree), the lock/unlock event gets generated many times, and this seems to increase.
Am I missing something obvious? When I first loaded EventGhost, it only fired once, so I am confused as to why it keeps increasing, and can't use this event until I figure this out.
kmc
Re: SessionLock/Unlock triggers multiple times
Post by kmc »
had the same issue, 4 events on logon. Tried a new blank EG tree and had 9 events. Reloaded the previously used tree and had only 1 event (as it should be).
Not really a solution, but it works...
I have the same problem, i.e. both:
' System.RemoteDisconnect [u'blaher'] ' and ' System.RemoteConnect [u'blaher'] ' are getting fired about 20 times in a row now.
