sending info
ntk1
sending info
Post by ntk1 »
hello
i want to send information received from my amp, when i send the command "DIF02" i received this event back
OnkyoISCP.IFA 'HDMI 1,PCM,48kHz,2.0ch,All Ch Stereo,7.2ch,'
OnkyoISCP.IFAHDMI 1,PCM,48kHz,2.0ch,All Ch Stereo,7.2ch,
now i want to send this line with network event sender but i have no idea how, so if someone can help me with this... :D I'm using onkyo ISCP plugin
thanks
piert
Re: sending info
Post by piert »
You really need to explain in more detail what it is that you are trying to achieve and......
my initial thought is that you have not invested much time in searching the forum before you posted....
ntk1
Re: sending info
Post by ntk1 »
If you did not understand what I want to do, how you concluded that I did not invested much time in searching?
i'm using onkyo ISCP to send commands to my amp, when i send "DIF02" command to the amp, the amp send back this info (as an event)
this info show the audio output i stream to the amp, now i want to use network sender plugin to send this info from the event the amp produce
this is script line to send XXXX with network sender
eg.plugins.NetworkSender.plugin.Send("")
but i don't know how to send the info received from the amp with network sender
thanks
cfull1
Re: sending info
Post by cfull1 »
That info is called the event payload.
Is there another machine running EG you are trying to send it to?
miljbee
Re: sending info
Post by miljbee »
Assuming you already have a second EG with network event receiver properly set up,
you just have to send eg.event.payload.
From what you wrote, it seems that the payload of the event is a string so you can send it directly, you will get that payload as the event suffix on the eg server.
<EventGhost Version="1610">
        EventGhost.PythonCommand(u'eg.plugins.NetworkSender.Map(eg.event.payload)')
If you need more fexibility, Try the TCP Events plugin, it will enable you to forward the payload as is with a fixed event suffix.
With TCPEvents, you can also parse the data at the client side and store the result at the server side without generating an event.
There is some other possibilities, but if you need more help from us, you will have to explain in more details what you are trying to achieve.
miljbee
ntk1
Re: sending info
Post by ntk1 »
thanks i manage to do it with EG App Control plugin and Log Monitor so i transferred the event to payload and send it with
eg.plugins.NetworkSender.plugin.Send("AudioInfo", [str(eg.event.payload)])
