PVR250 / Hauppauge "silver" remote
APillowOfClouds
Post by APillowOfClouds »
First, let me say I absolutely LOVE EG!! After struggling through Girder (And I'm a PROGRAMMER!) EG was a very welcome change - glanced thru a 2 page tutorial and I was good to go.
I use mostly USB-UIRT's but on my bedroom machine which is the one in which I have my TV Tuner and have Beyond TV server installed, I use the "Hauppauge silver" remote that came with my PVR 250 card. Is it possible to pick up events for that remote with EG? I apologize if this question's already been answered, I did a quick search and couldn't find anything, at least nothing that wasn't in German LOL
TIA
Rob
Re: PVR250 / Hauppauge "silver" remote
Post by Bitmonster »
No, there isn't one. But it shouldn't be to hard to write a plugin for it. A quick search revealed, that the IRREMOTE.DLL of the driver package can be used. Here is the header file I found:
 * This file was produced from documentation provided by
 * Hauppauge Computer Works. It is released under the
 * GNU General Public License
 * Peter Heitman, Oct 2003
 * Denybear, Apr 2005
#ifndef _IRREMOTE_H
#ifdef __cplusplus
extern "C" {
#endif
 * General Notes
 * The basic sequence is IR_Open(), and this starts a timer;
 *  poll using IR_GetKeyCode() called from the WM_TIMER messages,
 *  and then call KillTimer( hWnd, 1) and IR_Close() when you are done.
 * With the release of the v2.45 IR remote driver for PVR150
 *  (in conjunction with the HCWPVR2 remote), the IR_GetKeyCode () has been more
 *  or less deprecated (and for sure does not work with that version of the driver).
 *  You should use IR_GetSystemKeyCode () as a replacement.
 * The basic sequence is then IR_Open(), and this starts a timer;
 *  poll using IR_GetSystemKeyCode() called from the WM_TIMER messages,
 * Defines
#define IR_NOKEY	0x1fff
 * IR_Open
 * Parameters:
 *   hWnd is the window handle of your app. Timer events WILL be sent to
 *     this window if IR_Open is successful; the interval is nominally 85ms
 *   msg is UNUSED, set it to 0
 *   Verbose is a flag to indicate if a message box should be displayed
 *     with status during the open
 *   myIRPort is the I2C address to connect to; by default it should be 0,
 *     which does a search for any suitable device. You should set it to 0
 *     unless you have a good reason not to (hint: you don't :-)
 * Return Value:
 *   returns non-0 if it was succesful
BOOL WINAPI IR_Open( HWND hWnd, UINT msg, BOOL Verbose, WORD myIRPort );
 * IR_GetVersion
 * Return Value:
 *   returns the FW version of the found IR controller in the lower 6 bits;
 *     only useful for testing
DWORD WINAPI IR_GetVersion();
 * IR_Close
 * Closes down the existing connections to the IR device
 *   (Does NOT stop the TIMER; do that yourself via KillTimer( hWnd, 1))
 * Parameters:
 *   hWnd - currently NOT USED, set to 0
 *   msg - currently NOT USED, set to 0
 * Return Value:
 *   returns TRUE
BOOL WINAPI IR_Close( HWND hWnd, UINT msg );
 * IR_Power
 * Use ???
 * Parameters:
 *   msg - can have 2 values : either 0x12, either 0x34.
 *         No more information is available at the moment
 * Return Value:
BOOL WINAPI IR_Power( UINT msg );
 * IR_GetKeyCodeEx
 * Parameters:
 *   piRepeatCount  points to a value that contains the current repeat count;
 *     used to do auto repeat. This pointed-to value SHOULD be 0 initially;
 *     and should probably never be touched; and it MUST be Global/static
 *     (not stack based) (the IR_GetKeyCodeEx function assumes this state
 *     variable is preserved across calls)
 * Return Value:
 *   returns the current IR button press, or IR_NOKEY for no button pressed
 *     since last poll
 *   The format of the returned KeyCode is the 14bit RC5 code;
 *   bit:   13 12 11  10 9  8  7  6  5  4  3  2  1  0
 *   cmd:    S  S  T  A4 A3 A2 A1 A0 C5 C4 C3 C2 C1 C0
 *   S= status, always 1
 *   T= toggle, changes for every physical keypress (but not auto repeats
 *         from held keys)
 *   Ax = Address bits (0=older black remote, 31=HCWPVR remote)
 *   Cx = Key codes (look at the full list for each remote in
 *                   \windows\IRRemote.ini file)
 *   This is a low-level function; It is called by both IR_GetKeyCode()
 *   and IR_GetSystemKeyCode ().
WORD WINAPI IR_GetKeyCodeEx ( int* piRepeatCount );
 * IR_GetKeyCode
 * Parameters:
 *     (not stack based) (the IR_GetKeyCode function assumes this state
 * Return Value:
 *     since last poll
 *         from held keys)
WORD WINAPI IR_GetKeyCode( int* piRepeatCount );
 * IR_GetSystemKeyCode
 *   returns the current IR button press since last poll
 * Parameters:
 *     (not stack based) (the IR_GetSystemKeyCode function assumes this state
 *   piRemoteCode points to a return code that is <0x1F :
 *     (0=older black remote, 31=HCWPVR remote, 30=HCWPVR2 remote)
 *   piKeyCode points to a return code that is <0x7F :
 *     this is the key code (look at the full list for each remote in
 * Return Value:
 *	TRUE (non-0) if key pressed, FALSE if no key pressed
BOOL WINAPI IR_GetSystemKeyCode( int* piRepeatCount, int* piRemoteCode, int*piKeyCode );
#ifdef __cplusplus
#endif
#endif
Which programming languages do you know? I could write a basic plugin prototype for the DLL, but some fiddling has to be done with the actual hardware at hand and I don't have a Hauppauge card here.
Barf
Post by Barf »
I am not sure if it helps (using the Hauppauge CARD). but the said remote sends standard RC5 commands with device code = 31 (decimal). Can be read with any EG supported IR input device. On request, I will mail/post the key codes.
nightrader_
Post by nightrader_ »
Bitmonster wrote: Which programming languages do you know? I could write a basic plugin prototype for the DLL, but some fiddling has to be done with the actual hardware at hand and I don't have a Hauppauge card here.
I would be happy to help here. My python skills are VERY limited, but I would be happy to test, I have two HVR-1600 cards with the silver remotes.
Nightrader
