I have the Problem that Eventghost doesn't work with the Wireless Controller,if the Controller isn't turned on. I think that is because the device needs to be turned on, when the GenericHDI plugin starts, to work properly.
Is there any way to Start a Plugin when a device is connected or another workaround?
Greets from Germany
Jupdi
