Remote does not work from save...
SouthSeaPirate
Post by SouthSeaPirate »
I can have a couple of commands working, save, close, open; no longer works. I have to remove remote plugin and re-add, and all will work again. I cant imagine this is by design, as I wouldnt want to reset this everytime I go to turn on my HTPC. Any ideas?
Win8 Pro
Latest version
cfull1
Re: Remote does not work from save...
Post by cfull1 »
I don't think your giving enough detail for me to be able to help you out.
Which plugin isn't working for you?
