Hi !
Need the help to someone to store datas in SQL database
I am lauching a PHP script every minute to store some data in a SQL database. I use the Timer plugin with a macro-command and a start program.
- <Macro Name="Start Program: php-win.exe" Expanded="True">
<Action>System.Execute(u'C:\\UwAmp\\bin\\php\\php-5.3.5\\php-win.exe', u'script.php', 0, False, 2, u'C:\\UwAmp\\www\\domotique\\domotiquestudio1\\ipx800', False)</Action>
The script works well but fail when I try to store the data in the SQL database. i don't know why. I suspect a question of path but am not sure.
Nota : my script worls perfectly when I use another trigger coming from another device.
Thanks for the help !
Fred
