I have 2 problems that I need help with. The first problem is...I tried to follow the instruction I found on the totalhtpc site on how to set up a fully automated media center. In the set up I told utorrent to my movies from yifi rss feed in a folder called movies, the TV shows from eztv rss feed in a folder called TV, and also set uTorrent to put finished torrents in a folder called finished torrents( that sends everything I manually download to that folder for some reason even if I label it movies or TV and I would like to fix that too). The real problem is that uTorrent stores the movie torrent files in the movie folder while they are downloading and the same for TV. The directory watcher sees a new file and starts the process of copying the file to another folder and starts the renaming and scraping to the unfinished torrent. How do I make it wait till the torrent is completely in to start the process. In uTorrent settings the option to move completed torrents to...works fine but it moves both movies and TV shows to the same folder which does not help.
My second problem is...I have a NAS that all my media is stored on, so at the end of the whole process I need eventghost to then move the folder with the movie, fanart, subs, etc. as one folder. At this point the python script makes it copy the files and not the folder and I end up with movies and their info on my NAS without a folder and XBMC does not like that.
Any help would be greatly appreciated, Thank you.
