my Terratec remote sends signals like this:
IgorPlugUSB.unknown.23DF77DF6C
IgorPlugUSB.unknown.10
Directly after sending a signal with the individual key code, it sends "unknown.10" afterwards, even if the key is pressed longer. If I define a macro for "unknown.23DF77DF6C" and add autorepeat, the signal "unknown.10" breaks autorepeat.
How can I fix this? Is there a way to ignore all "unknown.10" events?
Thanks for any hints.
